Lazy Wife.Need help with remote starter.
aussieflash
G,day,Can anyone tell me where to hook remote starter while I check timing at cranking speed.
Also do I need ignition key on or off?
88 V6 135HP.
Thanks Paul.
Re: Lazy Wife.Need help with remote starter.
Ignition key needs to be on. You may use a simple clip lead to jumper from red cable on starter solenoid to yellow (or yellow/red) wire on starter solenoid. I recommend you remove spark plugs 2-6 and install them into their wires, tape them together and ground them to the block. This allows max timing adjustment w/o running motor.
You may want to disconnect idle stabilizer, if you have one.
aussieflash
Thanks Chris.I'll be giving it a go tomorrow.If you don't here from me...something probably went wrong.
canoemang
I use a 8' pole with a notch in it.. it reaches my key and i can do what i gotta do.
It is however a bit of a rig job so.. id follow Chris's advice :)
