lazyriverrat
- Joined
- Oct 3, 2010
- 11
I have an 8 hp Mercury motor vintage about 1982 that was always a fast start and never gave me any problems until last week. I was running the motor on a fishing boat in the river and did'nt feel like the motor was doing full speed at wot in forward. I pushed the control grip handle under pressure and heard a clicking noise that put the speed i was going into even a lower range. Took the boat to a local mechanic and he showed me that the connecting rod popped off the cam on the front and back. He had the motor for a week and gave it back to me. I took it out and was able to shift into the other positions for several times when the same problem occurred. All he did was lubricate the linkage and pop the connecting rod back into place. The only thing that saved me a long row back to the dock was the fact that I knew what part of the motor needed to be looked at. I had to manually reconnect the front of the rod to the cam it was attached to and physically hold it in place to shift the boat from neutral into forward gear. After doing this multiple times the plastic socket where the cam ball attaches became very sloppy and loose, not tight fitting like it should be. I dropped the motor off again and am waiting for the results. I think this mechanic is doing trial and error repairs without knowing the real reason I'm having the problem in the first place. I think something other than just this rod being popped needs attention to see why it is not shifting smoothly to begin with. Lubeing everything only seemed to work for a short time. Any and all comments welcome at this point. Maybe I can save my mechanic some time with experimentation.
