mayorj1227
Thread starter- Joined
- Feb 14, 2022
- 40
What does that lead shot do. Is it for low speed idle
Cold start idles great till it warms up, then start shaking like flooding out. Rebuilt carb. Ck plugs, 1 good burn the other blackThey generally are used to plug a hole where a passage was drilled. Most likely yes in this case an idle passage.
Thanks I'll ck that, that's the cylinder that's running rich that operates the pumpDon't have an answer for that, but think about it. Plugs seem to indicate one cylinder running richer than the other one. The carburetor feeds both cylinders equally. Have you considered a leaky fuel pump diaphragm? That would flood one cylinder.
Took pump off, notice the hole that feed vacuum to pump was wetDoes spark jump a gap of 3/8" ( 1 cm ) on both leads ?----Yes a leaking diaphragm is common.----New diaphragm are easy to get / make .----Easy to install.
put 2 gyproc srcews on a wood board 3/8 inch appart (top rims) ...easy as pieWhat kind of test device
Easy to check. With pump off and hoses still attached, give the squeezer bulb a squeeze. Fuel should not squirt out the pulse hole. If it does, diaphragm is shot.Took pump off, notice the hole that feed vacuum to pump was wet
Thanks guys for y'alls help. Problem solved. 2 of 3 pinholes for low speed and idle plugged up. Purrs like kitten now. Thanks againEasy to check. With pump off and hoses still attached, give the squeezer bulb a squeeze. Fuel should not squirt out the pulse hole. If it does, diaphragm is shot.
