Thanks y'all. I have 2 batteries installed with an on-board charger and plan to wire one bilge pump each to each battery directly. I got around to tearing the bellows/hoses all apart and cleaned up today, and it went smoothly. Before i got into it I figured out that it really isn't that hard to reach the shift cable pull through on the transom, although it is blind. I also watched a bunch of different videos on the process so I have a pretty good idea of the process before hand (I have the manual too, but I find that it sort of jumps around to various components without a super clear order of removal and install). The biggest thing I learned, which came in clutch was to break loose the hinge pins before removing the outdrive (to keep the bell housing locked in place). This unit has never been serviced so it still had the red loctite, which meant propane torch, breaker bar + cheater bar.
What is the common practice on the aft side of the shift cable bellows, do you use the supplied metal clamp? Or go with a strong zip tie? I've seen both methods, curious which one seals better.
