Leak on my Alpha 1 on shifter rod
karayj
ok, OP is on land but sure...I forgot you do your maintenance while bungee jumping... Seriously maybe if you had a small copper tube on end of lube pump (or lube tube) that would let air out (while its in the vent plug hole) you could probably top up with out removing the cap? or remove the cap if you prefer
If the outdrive and need to be topped off it works 3-4 inches . No bungee I was a cert mercedes mechanic and we dont always go by the book you can go rogue and still be fine ........now an empty outdrive YES fill form the bottom.
karayj
There is no bungee jumping if you are low by 2 inches or even 4 . If you are empty then yes. start at the bottom . I was a certified Mercedes mechanic and we went rogue "bungee" many times and it was fine. One one occasion a Bungee scenario got added to the technical data sheet at a fix method.
karayj
Sure... as long as a bolt doesn't break or thread in housing strip, which can happen on older drives. Point I was trying to make if you are trying to skate through to end of season touch as little as possible, you would have seen the color of lube and how much it was down by how much more you had to put in...You should replace the oring on there too.
The upper bearing there shows corrosion maybe some pitting from moisture damage. You can rebuild the drive, but what most folks do is buy a new SEI aftermarket drive and bolt it on. I believe they have a 3 year warranty and the price point is perfect for those of us who keeping older boats going on a budget. Usually less than cost to fix a drive or buy the tools to do it.
You want me to buy a $3,000.00 outdrive for a 1989 3.7 boat? that is a replace to repair . it would be cheeper to get a used boat 2005 for $4000. I would rather spent 80.00 and rebuild it .
Ayuh,..... The special tools to do it right is the expensive part,......
