olddawgsrule
Thread starter- Joined
- Jun 30, 2014
- 73
Why did I do an Internet search when it lead me right back here??
I see this has be addressed, but I thought of making it new again and learn some more from you folks.
The thread I read (and posted on) talked mainly of rivets leaking and replacing using aluminum rivets and 5200 marine epoxy.
This works for me and will cure a few of the leaks.
The major one is on the keel and was worn down from rubbing on the rocks.
What to use to rebuild and seal this?
Second one (actually 3rd & 4th ones..) is the seam along the keel.
Whatever was in there before has separated.
Again: What to use to seal this?
I have the boat flipped over now and ready to start the repairs.
The rivets were worn down from the rubbing and should be the easy part to repair.
The other leaks are loose bolts from the transom board (backer) needing to be replaced..(another easy repair).
The seam leaking looks like it dented or lifted just enough to separate the sealant between the body and keel (this one I really could use some advise on..)
