leaking drive oil from port side bellow. Where is it leaking from?
td192
2007 5.7 penta
I noticed a white milky oil leaking from the top side bellow. I checked the drive fluid, and it is low, but not out
I believe the leak is from the drive shaft seal.
How difficult is it to replace?
Any specialty tools required?
Don S
Re: leaking drive oil from port side bellow. Where is it leaking from?
You have two bellows (with an s) a ujoint bellows and the exhaust bellows. The ujoint bellows is above the exhaust bellows. Not port and starboard.
A picture would be a good idea so we know what you are asking about.
How to Post Pictures - The Basics?/ 468676
td192
Yes, you are correct. I was just standing on the left side of the boat when I was looking at it.
It is actually a tear in the top bellows where the fluid is leaking from. From reading other posts, I am thinking it is the seal at the u-joint.
Either way it looks like I need to remove the bellow for replacement, and I can inspect the seal.
Thank you for your reply.
