I recently rebuilt and successfully broke in the engine with no problems. For the 3rd time I'm having to replace the outside exhaust gasket on a 77, 75hp Evinrude. It runs great until the gasket leaks, (like a high pressure stream). After it starts to leak, the engine sounds like it's sneezing. There does not appear to be any water in any cylinder. This time I'll apply more sealer to the manifold on install. When leaking, does this affect compression causing the engine to run eratically? Is there an underlying problem, or do I just need more gasket sealer as suspected? One other thing, is there a way to replace this without removing the powerhead from the engine?<br /><br />Thanks
