Hey guys, I have a Yam 2002 15hp 4 stroke.
I use it on my duck boat and have been cranking it up every few weeks for the past few months and this past weekend had some issues keeping it running. I think it's sucking air through the fuel hose at the point it enters the carb. My question is this. When you squeeze the fuel bulb, and the line is full, should it squirt fuel out of the line at this point? The little wire clamp on it can be very easily squeezed with your fingers like it really has no clamping power at all. It seem to me if fuel can pass through that point then it would be just as easy or easier for air to pass. It will run for 10 seconds or so then die.
Thanks,
Chris
Thanks,
Chris
