leaking gear lube externally
ronnie bill
I just replaced the water pump assembly now it is leaking gear lube out around the shift shaft assembly externally. I put about 40 ounces of lube in it is that normal?
Re: leaking gear lube externally
Ayuh,...Did you put the quad-ring inplace,..??
ronnie bill
yes I did it's not coming out the weep hole it's on the upper shift shaft.
Bt Doctur
Did you assemble the drive properly with not binding?
Alpha or alpha GEN II?
