Hooked on Deanna
Thread starter- Joined
- Feb 22, 2009
- 142
It turns out my leaking shaft seal was allowing water into my lower unit. It cost $400 to repair and the mechanic said I may need to replace the lower unit in a season or two - said that corrosion on the shaft and gear will eventually fail and I'm licky its a volvo/beefy else it would need to be replaced now. He also said the upper gears were not getting lube because the level was low - I checked the level before the repair and it was low but I did get oil on a pin that was about a half inch longer than the dip stick. The oil on the pin I used was clean and the oil leaking out of the shaft seal was clean.
Any comments...
Any comments...
