TrickyRicky
Thread starter- Joined
- Jul 17, 2012
- 37
78 Johnson 55hp
Water intrusion in gearbox. Pressure tested and found the shift shaft seal to have a leak.
I can unscrew the shift rod and unbolt the shift cover to replace the o ring, gasket and shift seal
Question I have is will I be able to re install the shift rod from the top without dis-assembling the gearcase?
I don't have the 2 pullers and the shaft socket to be able to disassemble the gearbox that is why I ask
