I just installed a new sonar unit and mounted the transducer using one of two previous mounting holes used for my old unit. I reinstalled the old screw back in the left over hole from the old transducer mount and coated the threads with sealer. I took the boat out on the water and my bilge pump had to be used. The mounting bracket on my new transducer is made so that the mounting screws are left a 1/2" away from the transom when tightened. I assume my leak is coming from there since it did'nt leak before I replaced my old sonar and transducer. Yes, I coated the threads on the new transducer when I installed them. If anybody has any suggestions/advice that would be great!!<br /><br />thanks, pjw
