powderhombre
Thread starter- Joined
- May 26, 2009
- 35
1982 stringer OMC 800 upper gearcase. did water pump job in spring everything looked and worked good. filled case with clean gear oil from bottom plug till oil popped out top fill hole, too much, I know. So drained a few ounces out, till dip stick showed proper amount. went boating for 4-5 hours. drained the gearcase to check for water as I do after every outing, and only about 2 oz. of oil came out and it did have milky look, but no actual water. drained and filled with fresh and is now stored indoors for winter, no oil leaking on floor. So, where is the oil going, and is it possible that cooling water from the pump is getting into the case, and gear oil getting into engine cooling system?
