mrnmrskyle
- Joined
- Apr 8, 2013
- 56
well, was 40 miles off shore coming in last sunday and came to an abrupt hault... trimmed up and had hit a 4ft long 8in thick piece of rope wrapped around port engine... got it off, ran back in, no problems, water pump pushing like it should, running like it should, no issues.... but when i loaded up i hooked up the hose and water came out around the seam from lower unit to the shaft housing part (or whatever it's called that the lower unit bolts too) it is coming out around the seam where i bolts and on the back where there are the square covers ( i think they are covers) is this bad? asked around a little and everyone said that it was no issue just the seal between the two (which has no gasket) was broken.
it's a 1995 johnson 150
