Re: Leaky Float Bowls
Do you have a seal on the screw on the inside and outside of the bowl? Look like two small red colored washer gaskets. Just a guess.<br /><br />Is it leaking from the screw at the bottom, gasket at the top or the overflow hole on the upper side? Overflow leakage on the top is a float/needle valve issue.<br /><br />I'm no pro, just throwing some ideas your way.<br /><br />Dymo
