leaky vro
gmeys
I have a 1986 e70elcdc. When I prime the motor, I get a leak at the very end of the vro unit at the top. Is this nomal and or repairable.
EN2
Re: leaky vro
Check primer solenoid. Red handle.
ezeke
Re: leaky vro
If the leak is at the fuel outlet at the top of the 1986 VRO pump, the fitting is not repairable, but a better clamp will sometimes solve the problem if the hose is loose.
Fix the leak or you will run lean.
