guy74
- Joined
- Jul 12, 2007
- 794
Hi everyone,
I'm working on a 1989 Evinrude 100 hp V4. It seems to run lean on one cylinder at idle. I have taken the carbs apart and checked to make sure the idle passages were clean. The carbs were rebuilt in 06, according to the previous owner, they were spotless inside. It seems to run lean on number 4 cylinder at idle, if I cover the idle air bleed for that cylinder with my finger it smoothes right out. I'm not sure where to look for the cause of this problem. The motor seems to be in very good shape, good spark on all four, good compression(120,120,119,120).
I'm kinda stumped looking for the cause, I think it must be a vacuum leak, but I'm not sure where the most likely places are to look.
Thanks,
Brian
Thanks,
Brian
