LubeDude
Thread starter- Joined
- Oct 8, 2003
- 6,945
Last Fall, The Boss bought a 1965, 350 HP, 327, A/C, Corvette Roadster. Nice car, been sitting a few years. I rebuilt the carb and did some ignition work and got it running good enough to drive. It had a bad oil leak, (I think I mentioned this before) so I changed the rear main seal. Well, he took it out one afternoon and came back and said, " Man, this car has a BAD vibration at about 2,500 RPM, Its not even drivable". I took it out and Wow, he was right. The vibration wasnt there when I drove it before though. Checking things, I found that the yoke on the trans end of the driveshavt was worn and the universal joints were not good, so I started a repair process than ended up with me pulling the transmision also. So, rebuilt the transmision, (needed it badly) Flywheel resurface, new preasure plate, new cluch, throwout, New yolk, new universal joints, resealed the intake manifold, new valve cover gaskets, resealed the oil sender and vent tube. Just got this project done first of this week. Took car for a test drive thinking all would be fine. NOT!!! Vibration still there, and now the water pump is out. So fixed that and start looking for vibration. Actually took it to a friend of mine for another opinion as I had ran out of Ideas. He had me start it up and he felt of the car and reved it up. He motioned for me to get out of the car and come to the engine compartment and have a look. He showed me that the fan assy (Fan and Clutch) was wobbling some, He said to change the fan cluch and the vibration would go away. So I did and the vibation was somewhat better, but still there, so I looked at the fan while the engine was running and noticed that there was still some variation, so I did away with the clutch and fan all together and the vibration was totally gone. Now it has a flex fan and spacer which I painted black so it doesnt stick out like a sore thumb and everything is fine now.<br /><br />So, the senario was, Fan being out of ballance took out the clutch which took out the waterpump bearing.<br /><br />I never would have thought that a fan could make such a terrable vibration, I mean it was so bad you couldnt drive the car above 2,500 RPM.<br /><br />Oh, No more oil leak!
