Leave water in or drain?
SeaRayboater95
Hi people;
My boat will be stored in a heatted shop all winter. I'm wondering if I should drain the water out or leaave it in. Which way promotes more rust? I will be changing exhaust flappers or at least inspecting them because I think I hear one flopping around in the pipe, but most likely not for a few months. I think if the cast is not exposed to air, oxydization will be slower. Opinions? Thanks, Ken
Re: Leave water in or drain?
Hi people;
Ayuh,.... The amount of rust, in a freshwater boat motor is pretty much irrelevant....
It rusts danm little, wet or dry....
As for the water in the block,....
What are gonna do when the heat goes out in the shop, 'n it's -35? outside,..??
Drain it......
starsnstripers
Ice storms, power outages? Unless it's backed with emergency generators, drain it!
SeaRayboater95
I guess that makes sense,although never had that happen yet. There is always that first time. Thannks guys.
Ken
$10 in propylene glycol is much cheaper than a new block. my vote is to drain it, then pour in some marine/RV antifreeze
Fordiesel69
I always stored mine with antifreeze for peace of mind. However this year I may flush with antifreeze and leave dry. My vote is to get the water out in case the building looses heat for some reason.
duped
It takes what, all of 2 minutes to pull the drains??? And you never have to worry about any what ifs.
