dpostman21
- Joined
- Apr 20, 2016
- 53
After the installation of the 6.5” Enrock speakers with LED ring I have a pulsing noise in the sound system, does not do it when speakers are on solid colors just when it cycles thru the colors. I have installed a Superbright LED controller (TQ Nusic 2 RF controller), since then the noise is annoying.
Controller thats cause noise: https://www.amazon.com/gp/product/B00JQ3QOSY/ref=oh_aui_detailpage_o01_s02?ie=UTF8&psc=1
I have a the XGlow LED system installed as well and don’t experience the same level of noise in the sound system a slight hum at low volume. This controller is WiFi based and not RF.
I have ran new 14 AWG speaker wire and 14 AWG power/ground wires to the speakers & RF controller. Power goes to brand new Blue Sea 5 circuit fuse block which is powered by the common on the battery switch and grounded to the battery I have a 4 AWG power to fuse block and a 6 AWG to battery ground.
What I have tried:
I have 2 batteries, New JVC head Unit, 6 6.5 Enrock speakers, 1 Pyle 400 watt marine AMP & 1 8” sub/AMP running about 15 feet from batteries using 8 AWG for power and ground.
Thoughts???
What I have tried:
- Using an independent battery not connect to the boat to power controller, sound was there but not amplified to bad.
- I have tried running directly off one of the batteries with the same result of noise while cycling colors.
- Checked and double check the RGB 4 wire on all speaker to ensure nothing is crossed or hooked up incorrectly.
Thoughts???
