LED Lighting
drewpster
I want to get some LED lights to go under the gunnel of my tri-hull to light the deck. At first the idea was to use rope lights, but I do not like the way they connect together and the price is pretty high. I am having some trouble selecting what would work. I want to go with LED to add allot of light while saving my batteries. Any suggestions on what I should go with? Anybody had any experience with 12 volt rope lighting?
trendsetter240
Re: LED Lighting
I used small 6 LED units that I picked up from West Marine. They are about 3.5 inches long and throw a very bright, white light. I think you can also order them here on iboats. They were about 10-15 bucks each. One on either side provides plenty of light and use virtually no power.
fishrdan
Re: LED Lighting
I used red 12V rope lights in my boat, got them from CBConcepts, 4- 6.5' ropes were something like $50. They light the boat up pretty well, but if I want to tie a knot (fishing) I have to get 1-2' away from the light.
I do agree the connectors are kind of chincey... I took them apart, slathered it in 3m5200, put back together and tightened it down.
bkwapisz
Re: LED Lighting
I got some of the little passageway LED setups from here at iboats and put them all over my fishing rig to help at night. Gives a nice light that isn't too harsh so that your eyes can't adjust. Used to have some crappy things with what looked like nightlight bulbs that didn't work half the time unless you jiggled them. These were great replacments and were cheap.
sasto
Re: LED Lighting
I have rope lights in the cockpit and cabin for 15 years....no problem....I used heat shrink in the connections and they are used in saltwater enviroment. Depends on the manufacturer, I buy them by length that come off a roll, which can be cut as desired to fit your application. Commonly called "sex lights" around here. More for visual or safety effect. Red for cockpit and blue for interior. Red is easiest on the eyes and blue second.
roozter2550
Re: LED Lighting
just installed a 48" strip on each side under the gunnels and 4 10" strips under the t-top...
these pics are just the under gunnel lights...haven't taken pics with the t-top lights yet...
paid $8.99 for each 48" strip and $7.99 for the pack of 4 10" strips
hard wired to the boat's electrical system
48" strips
http://cgi.ebay.com/ebaymotors/ws/e...0473807464&viewitem=&sspagename=STRK:MEWAX:IT
http://cgi.ebay.com/ebaymotors/ws/e...0474118691&viewitem=&sspagename=STRK:MEWAX:IT
this seller has other colors and lengths available as well...
I'm picking up some red strips for night running next
(sorry about the crappy cell phone pics)
(BTW, the pics were taken during daylight, under a cover which is full open at the stern)
roozter2550
Re: LED Lighting
here are some better pics...(ignore the date stamp on the pics, set it wrong)
fishrdan
Re: LED Lighting
WOW roozter, that baby is lit up!
How many strips did you use on each side, size and total strips.
I want to add some white LED courtesy lights, for when the red's are not lighting the cockpit up enough, and those strips look like they would fit the bill nicely.
sprintst
Re: LED Lighting
Awesome lighting Roozter. Hopefully mine light up the same...
drewpster
Re: LED Lighting
That is exactly what I am looking for! Good price too. How do they wire in? Are there pigtails? Did you have to solder the connections?
roozter2550
Re: LED Lighting
two 48" strips, one on each side under the gunwales
four 10" strips under the t-top...you can see the locations in the 1st pic
roozter2550
Re: LED Lighting
The strips come with pigtails...(reasonably long too but not terminated with a connector so soldering is needed)
I soldered and sealed all the connections liquid elec tape and heat shrink over that.
I mounted the strips with 3M automotive body molding tape and also used a couple of zip-ties on the t-top tubing.
drewpster
Re: LED Lighting
Thats Great, thanks for the help all. Given the price of these LED strips it leads me to believe that the other ones I have been looking at are way overpriced. These are cheap enough I may go with blue and white. good deal.
BTW- How is the seller on shipping? reasonable?
fishrdan
Re: LED Lighting
Thanks for the info roozter. I didn't see the T-top LEDs at first, looks good. That white interior really reflects the light well.
drewpster
Re: LED Lighting
Heres one for ya, Should LED's be wired in series or parallel?
fishrdan
Re: LED Lighting
Parallel.
The LED's I've seen don't use expensive wire, zip cord or speaker wire. I have some tinned speaker wire that looks just like the wire of roozter's LED strips....
