Left side lean?
Ground Pounder
Hello troop's, I purchased a 2003 Aqua Sport 175 CC, w/h a 115 Suzuki 4 stroke, the boat and engine have less than 300 hours run time on them, she's pretty much a very new combo, here's the issue I'm having, at speed she has a pretty hard lean to the left, I've tried the hydro foil on the engine, no luck, I have installed a set of automatic "Trim" tab's, NOPE! Neither have brought the boat to run true and flat at speed. I'm out of option's? Side note, I'm not a boat guy, I'm a retired mechanic so working on equipment is a non-issue, any ideas on the hard lean?
airshot
While this may sound dumb, I have saw it many times.....is the motor hanging off the transom correctly ? Have saw a few that hang at an angle, or the transom cutout was not parallel to the bottom if the hull, especially on glassers. Another issue could be a dent ( hook) in the hull causing a list when on plane. Mabry some videos to help us see your issue...good luck
jlh3rd
" I'm not a boat guy"
I'm responding based on this.
Do you mean "leaning" or "turning".
Some outboards have an adjustable trimming tab on the lower unit that's also an anode. This trimming/anode tab is used to straighten the boat, if needed, at speed once properly trimmed.
(picture))
Also, you change props to keep engine rpm's in the manufacturers specified rpm @ WOT (wide open throttle) , not to correct an untrimmed situation.
boscoe99
The trim tab anode is used to correct the tendency of the motor to turn left, or right, which can vary as the motor is trimmed upwards or downwards. Motors with conventional gear cases want to turn right when trimmed down and to the left when trimmed up.
jimmbo
Does the List increase as Speed goes up?
Run a Straightedge on the Starboard side of Hull from the Transom forward, and look for any gap forming. I am suspecting that the Stringers have rotted out at the back allow the Hull to flex, creating a Hook. It is a 23 yr old boat, and I suspect your don't know the History of the Boat, other than the Seller told you it was 'Excellent'...
