Legal carry-on 5 gallon gas cans?
Fordiesel69
I would like to buy plastic 5 gal gas cans to carry on my boat. I need it to have a vent cap and a traditional spout. I am only finding non vented push release spouts that are very tricky to use. It has a spring that you compress to start the flow. Any idea where to buy a traditioal gas can that can still be legal to carry on?
ezmobee
Re: Legal carry-on 5 gallon gas cans?
Let me know when you find some! I HATE those stupid new spouts and they are about all you seem to be able to find nowadays.
arks
ezmobee- I've had good luck cutting the spout off at the spring. Only problem is the spout is kinda short. The old flexible spouts were much better.
I see the old style 'non-safety' cans on Craigslist from time to time and try to get 'em fast.
smokeonthewater
You won't find vented gas cans in the usa any more..... The epa believes that a non vented can will recover the fumes from the gas tank and hold them to be recovered by the gas pump so they outlawed the production of vented cans.:mad: I have a couple old 6 1/2 gal cans and was able to buy some replacement spouts for them a couple years ago but I am dreading the day they die..... You may be able to buy a vented water can of the same material but it won't technically be legal for gasoline....
Edit I see this has gotten worse as of this year..... there should still be some out there but it appears they are not being manufactured any more
http://www.blitzusa.com/faq.htm#R
jay_merrill
I didn't know that this is an EPA thing. I agree that the new jugs are a complete PITA. Such is life, I guess.
rbh
Your best place to find the old style jugs is at a garage sale or a mom and pop hardware store were there's probably not a huge turnover of stock.
roscoe
Not EPA, but CARP.
Once California passed the law, the manufacturers chose not to make 2 different product lines.
Check out the race fuel jugs on the net, they look to have potential.
Also, I know of several people that have added a vent to their new fuel jugs. One guy uses a valve stem and cap, just remove the stem.
jdlough
I like the Eagle 5-Gallon Metal Gas Can. I got it at Lowes.​
There's no vent, but it doesn't need one. It has a big wide mouth spring loaded cap (kind of like a whistling tea kettle) and dumps the gas into the attached funnel, thru a hole in the side of the funnel. The cap also seals very well, and it's easy to control the gas flow.​
Just position the funnel and open by pulling on the cap handle SLOWLY, to be sure you don't dump too much gas at first.​
ezmobee
That's not a bad alternative jdlough...
lckstckn2smknbrls
When I see a gas can on the side of the road I pick them up. Sometimes all that is good is the spout.
