If you're chatting up the chicks in the bar, it's at least a 25 footer.
You can't buy that kind of wisdom these days! Well put!If you re selling it . . . it is a 20 footer . . . and if you are buying it, it is a 19.![]()
Length as described by the Coast Guard Regulations.
Length means a straight line measurement of the overall length from the foremost part of the
vessel to the aftermost part of the vessel, measured parallel to the centerline. Bow sprits,
bumpkins, rudders, outboard motor brackets, and similar fittings or attachments are not to be
included in the measurement.
The key words there are 'fittings and attachments.' Bolt-on swim platforms and bowsprits/pulpits/anchor rollers are typically not included in the LOA measurement. When they're molded into the hull (very common on newer boats), then they are included in LOA.
If you're paying for dock space, bottom painting or storage, it's 19'.
