Lesson learned
DeepCMark58A
That is why I use real antifreeze and Pickle the motor for the winter, I don't trust pink slush.
JimS123
So what happens in very sub zero areas ? Most of their winter.
Please NO O B lovers reply's.
I personally drain the water, pull the TS, fill with AF and all is good.
Did that with Glycol. The first Summer when I saw green water on the first splash, I thought that ain't good. In future years I ran it on the muffs in Spring and let it run in the grass. In later years I used -50 pink stuff so I didn't contaminate the waterways.
Regardless of method my last step was to draw a pint out of the block into a glass jar and put it on the tongue of the trailer. My boats are garage kept so I could look at the jar every day as I jumped in the car to go to work.
My experience with an I/O was 35 years. I now have 2 OB boats in the garage. I won't admit to being a lover. My switch had nothing to do with Winterizing. It was simply because of U-joints, bellows, extra weight and the new need for a cat converter.
Never had an issue. The caveat is that it was not MOST of the Winter. Maybe a week or 2 below zero and the garage was at single digits or low teens.
I have friends that stored their boats outside and merely drained the water. One DID have a cracked block. I don't know if his procedure included pocking the holes, but obviously he still ahs some water that didn't drain.
Grub54891
Iv never had a broken block on any boat I’ve winterized. Done hundreds for customers, and many times of my own. Drain all water, run -100 through and go home. -50 is for fresh water systems in boats/rv’s, drinking water. Lately I don’t run anything in my engines and have been fine as long as you know that the water is completely out.
male, 68, size nine shoe, 160 lbs, no banana for scale but you get my drift.
