Lifting my 1994 Johnson 200
leisjohn
I need so help. I can't seem to find a place to lift the motor by. Is there a special bracket that is used when pulling the motor off? Thanks for your help in advance.:confused:
tashasdaddy
Re: Lifting my 1994 Johnson 200
they make a lifting eye that is bolts to the block, i'm surprized it does not have one. on small motors we use a flywheel puller sometimes. but i would not on a 200 hp.
leisjohn
Hey thanks for the reply. Any idea exactly where it mounts on the block? If I can find a safe spot I'm sure I can make do with chain...
tashasdaddy
not familiar with the particular motor. sorry.
CatTwentyTwo
Are you sure that you don't have lifting eyes cast into the motor? I don't know about your 200 hp motor, but my 94 175 has a lifting point on the top right cylinder and another just in front of the starter.
gregr1971
you can use a motor sling or 3- grade 8 bolts and a lifting eye bolted to the flywheel.
HybridMX6
Not sure it'll help, but my '93 60hp 3cyl. has a lifting eye bolted to it between the flywheel and the t-stat area of the block/head. I noticed it while disassembling the engine yesterday. I hadn't noticed it before that, it's a bit hidden unless you happen to look right at it.
SKEETR
I'd say NO to lifting a 200 by the flywheel. Treat the flywheel like the $850 balanced ignition part that it is.
Dhadley
There is no lifting eye on the block of that motor. The correct way to lift the motor is with the lifting ring bolted to the flywheel. People get by with something homemade but the best eye is the one you get from a BRP dealer.
