Texasmark
- Joined
- Dec 20, 2005
- 15,039
Seems to be some confusion as to just what do lifting strakes do?
Well, obviously, any time you increase the thickness of something, you increase the strength. In the case of a strake, you deform the glass mat to get the strake and the strength, but you don't have to pay the price of added weight like if it were solid. So ok, some builders may (do) add them for strength......course, everyone doesn't use them.
But the real reason is what you see if you look closely at the Avatar of "achris".
His 20' Bertram is one of the finest offshore boats in the world and has been for many years. Some of the reasons why are clearly evident in that Avatar.
While there, notice the lowest strake and the spray being deflected off it. Less hull in the water, less drag and with strakes, as you increase speed, these little water skiis help to lift the hull out of the water and reduce drag, plus help to cushion the impact upon reentry after a big wave.
Personally, I wouldn't have a deep V hull without them.
My 2c,
Mark
My 2c,
Mark
