What do you mean they don't work with braid?????
Mine are set up with 20lb test mono backing,...100 yards of 40lb test Power Pro, Then a short mono leader,..
Haven't had any problems with mine,......
And if you take your time filling them they can be very accurate,...
Mine where setup with #200 dacron backing, 300 yards of #80 braid with a 25 ft., #100 mono wind-on leaders.
I won two Shakespeare LC at a raffle. They went three or so outings before they started to "skip" mid-deployment, requiring reset to correct. Frustrating when you have 200+ ft. of line behind the boat and have to wind it all in and start over again.
Stopped working altogether by mid-season. Tore them apart to investigate. Found a cheap, little plastic gear mating with a much larger brass gear (levelwind) with little tolerance for alignment issues or wear. To the point that they worked with the reel laying on it's side with the counter pointed down. Didn't work with counter up or held in the usual upright position. Trashed them and went back to counting bars.
Counting bars is just as repeatable as a counter w/o the problems. Counting bars allows me to deploy the lines in total darkness. Something that you can't do with a LC. Comes in handy with money on the line (pun intended) and 20+ lines to set before sun rise.
I realize I'm no where close to light tackle trolling. Then again, #40 PP isn't actually light either..
I use #20 or less for LTT
