rogerwa
- Joined
- Nov 29, 2000
- 2,339
WE had a weird storm here last night. It wasn't severe but it was very electrical. I woke up today to thunder and lightning and one particular crack that we both saw and heard at the same time.
It wasn't until later that I found we had some odd damage. First, one of our phone lines went out. We have three phone lines and DSL coming in on two separated underground feeds. The original line is out.
Second, I found some other odd things. My garage door opener would not respond to the controls. I found this out when my kids came home from school and were locked out (Mom was running an errand).
I had installed an antenna on the eaves of my garage last weekend and hooked it up to a signal amplifier. This antenna fed my home built MythTv DVR (two antenna feeds into three tuner cards) and my TV set. I found my DVR all screwed up. The Video card would no longer feed the svideo signal to the TV and I suspect one of the tuner cards is toast as well.
On top of that, the signal went to crap from my antenna and i deduced (by removing it) that the apmplifier is toast as well.
Here is a diag to make it simpler:
I inspected the perimeter of the house for damage in the case the somehow I had missed a direct lightning strike and did not find any.
What would cause all this damage?? A static discharge on the antenna? or a big line voltage spike?? ideas? I do not believe the garage and the TV/DVR are on the same circuit. Also is there a way to protect myself from this??
Very weird.
Very weird.
