Lil' Dinghy
CalicoKid
Re: Lil' Dinghy
I went through all that scraping bad resin off building my canoe. It's no fun but the results are much better. I had a bad can of resin that would not cure properly. Between coats of resin, if you let it cure, be sure to wash the cured resin down with warm water and sand it with 80 grit. If you apply resin over cured resin, any kind, the new will peel away soon. If you do your layup all at once while the resin is wet or even kicked off but not cured you get the best bond, a single thick layer of plastic. If you do a layer and let it cure then do another layer you need to do the wash and sand prep to get a good mechanical bond between layers. Single layup is best but not always practical so be good about the surface prep.<br /><br />The link to West System has some info on poly (gelcoat) over epoxy in the boat projects section. Poly just doesn't make nearly as strong of a mechanical bond as epoxy does. It does make a fine chemical bond though which is why composite boats are laid up all at once in the mold. I feel epoxy is far superior to poly for home boatbuilding for this reason alone. We are not making these boats in a day. The lack of odor and the great accompanying products that make up the 'system' are bonuses. The only drawback is cost. :)
drwgblanks
Re: Lil' Dinghy
I wanted to bump my thread back to the top....just to tell you guys that......I HATE BUILDING DINGHYSSSSSSSSSSS. THis lil shyt is going to be the end of my sanityyyyyyyyy. I've gotten it mostly together, other than a few things, like the 4 compound angles that are probably going to cause my brain to spontaneously combust tomorrow. GRRRRR, I wanted this thing to fit true, and I'm pretty skilled with a saw. BUT Sheeeeeesh. I'm a painter, and I'm about to just take what I can get, and go get some caulk out of the van, and start filling gaps that I can't quit creating. Luckily I only have about 4 hrs in it so far, so I'm not too far gone yet.
cpj
Ensign
Re: Lil' Dinghy
Well you know what they say about painters,they are good with there caulk! :D
CalicoKid
Re: Lil' Dinghy
You could always use your poly or epoxy thickened with your choice of additive to the consistency of peanut butter to fill and fair the gaps and fiberglass tape over that. No one will be the wiser.
drwgblanks
Re: Lil' Dinghy
Hey guys, sorry it's been so long, I have been pretty busy at work. So we finally got back to work on the dinghy as of last night. We have started fiberglassing this lil thing, and I should have some pics after thanksgiving of the progress. it's all going pretty smoothly now. I was just having a helluva night trying to get some of those angles on my last post. This project shouldn't have taken more than a week or so at night, but my schedule has been so screwed up. Anyway, i'll try to post some pics either friday or saturday.
