Re: limited rpm from 40hp 1990 2 stroke yamaha
I take it that this motor is not a US motor, you never gave a model # and since you are using meter measurement and the word carby I would say you are not located in the USA.
read #9 on this post it helps us a lot to know everything .
http://forums.iboats.com/showthread.php?t=250876
Does your manual say if the plug caps are replaceable? My 1999 manual says that Canadian and European specs for spark plug caps are 4.0-6.0 K ohms but give no specs for the US
so I take it mine are not replaceable, but yours maybe. Make sure the black wire on the coil is grounded good and has no corrosion on the connector.
I thought you said the spark was good
What kind on meter are you using to take your measurements and what is the test unit you are speaking of that you are waiting on?
"The boat shop replaced the CDI unit and said they had tested the coils????????."
Did they do this like they cleaned the carbs and fuel system?
Did you get the old CDI unit from them that they took off? It may be a good unit still and even if it is not the wiring connectors might can be used to make a test harness.
Did you read the tread on testing the fuel delivery system? are you sure it is not sucking air?
