brian3127
- Joined
- Jun 10, 2007
- 525
I have a clymer manual for my motor.
And to do a link n sync it says to move the throttle control until the intake manifold projection is centered between the 2 throttle cam marks.
If the throttle valve is not closed with the cam follower roller touching the cam, loosen the throttle arm clamp screw and adjust.
That part is easy to figure out now the next step is confusing.
Manually rotate armature base to full advance position. Adjust control rod collar to provide 1/32 in. Clearance at the pivot pin.
The thing I don't understand. Is I loosen the screw to adjust the 1/32 in. Gap and then the throttle valve closes because the set screw is holding the throttle valve open.
Do I hold the throttle valve fully open and then set the gap I don't get it
And when I do the first step I push the throttle to wot and the throttle valve is open at about 1/2open
