Reggie08
Thread starter- Joined
- Mar 31, 2008
- 243
I need some help
Trying to make sure my first attempt at a link-n-sync on an 85 'Rude 90hp was done correctly. I finished a complete rebuild on this motor (burned up piston) and wound up replacing the block with one in much better condition (old one has scored cylinder walls and was already bored .030 over). In the process, I tried not to disturb anything I didn't need to i.e. timing screw, etc and took plenty of pictures prior to disassembly. However, since I moved everything over, I want to make sure I have this all set right.
I figured out the throttle plates. That was easy. Somewhat figured out my timing pointer (actually set it while I had the cylinder head removed but didn't use a Piston Stop tool)
My confusion really comes in when trying to set the timing advance lever. How far back is a good starting point? I'm assuming the throttle/shift cables should be removed. Where exactly should the cam follower be setting against the cam prior to moving the cam lever?
Basically, is there a "Link-n-Sync for Dummies" out there? I have an OMC Service Manual but with out any good starting reference points, it's hard to know if I'm doing this right or not.
