Link & Sync 1990 15Hp Evinrude
OptsyEagle
On my tiller picture above I can read the part number on the underside of it and it appears I have the 327944 Throttle Control Plate. Looking at the 174741 design it almost looks like it might just go over top of it or maybe it replaces it or maybe it does not fit "non-select models". I will take a closer look at my tiller and see how all this might work.
You guys have given me a couple of ideas so I thanks again for that.
OptsyEagle
I have a 1984 model 6 HP with 174741 installed.
Do you remember if that part had the "slow, start, fast" indicators on it like the 327944 Throttle Control Plate does? I am trying to understand how the part works and if it goes over the 327944, under it, or completely replaces it and if it would stop my throttle from moving on its own or not.
The idea of 174741 is to lock the throttle.----Say on a sailboat for a 6 hr trip !!----See or call your local dealer.----I do not have time today to look at this.----Grandkids , gardening and long weekend here.
OptsyEagle
No problem. I will get that figured out.
One more issue that I hope just requires a quick confirmation from a knowledgeable outboard user of my model vintage. I also noticed that someone has changed the orientation of my starter pawl (the red piece). Mine is the 1rst picture on the left and the 2nd picture on the right is from Leeroy's ramblings. Mine is not set up the same way and I suspect this might be important to prevent the motor from being started in gear. I am hoping someone can confirm this for me. I had a 1961 5.5 Johnson that I started, not remembering it was in gear, and almost did a nosedive out the back when she lurched forward. A 15Hp is not going to make this any safer. I put my motor in gear and I seem to be able to pull the starter rope out completely. I don't think that is right.
If the "no start in gear" is disabled do I also need the spring shown in the right picture or can I just position it on the other side of that metal piece on the starter. I don't have a spring. My guess is the spring is not there for cosmetic reasons but I have never had a motor with this mechanism on it before.
The picture on the right is correct.-----And just so you know it can be started in gear !!----The red mechanism prevent starting when THROTTLE is open too far.
When throttle is advanced too far that red pawl blocks the recoil from rotating !!!!
OptsyEagle
OK thanks. I imagine the spring is critical to its performance? I don't have one on mine so I will probably have to buy another pawl just to get a spring.
OptsyEagle
So problem #2 above, of the throttle slowing down on its own when you remove your hand from the tiller, has been solved. Racer's suggestion of needing part # 174741 appeared to be the best approach. I did not want to cut into the material covering my throttle cable under the tiller, so as to attach a clamp, as mentioned here and in Leeroy's Rambling, because my covering material is more of thick rubber winding tape wrapped along its length and once I cut it, to get at the throttle cable, I worried it would come fully unwrapped and I would have to cover it all with something else. The only issue I had with part #174741 was where it went precisely and what it actually did. I was worried that it was a sort of lock that one might tighten for trolling. My problem was stabilizing the throttle at higher speeds and one cannot "lock" a tiller at high speed because the ability to quickly unlock a throttle is effectively your brakes on a boat and the ability to quickly slow down, I think most of us will agree, is fairly necessary for safety on a boat. So I decided to see if I could replicate part #174741 (throttle friction control) with a simple hose clamp as shown in the picture below. It worked perfectly. Once tightened, one maintains full control of the twist grip/throttle but it does create enough friction to stop the twist grip/throttle from slowing down on its own, at all throttle speeds.
That problems was actually quite annoying. Thank you everyone for your help. I just wanted to post an easy fix for anyone who finds themselves with this problem and it also shows precisely where part #174741 would go and how it would go if you prefer the more BRP approved solution.
