Open Waters
- Joined
- Aug 14, 2011
- 32
Hello All,
After removeing my lower unit to replace my water impeller, I noticed a couple of small parts on the ground (see attached pics). I'm needing a little help figuring out what/where these 2 (two) parts are/go.
Is the small metal part in the first 3 images the "shift rod shaft". The piece seems to fit into the opening at the top of the "lower shift rod", Again, refer to the pictures.
The piece in the last 2 images appears to be a seal. Is this the seal for the "lower shift rod"?
Lastly, in which direction should the rubber impeller blades curve?
Thanks in advance - Open Waters
