findinghomer
- Joined
- Nov 7, 2009
- 332
Its designed to give the motor more fuel during acceleration. They are not used on many 4 and 6 cylinder motors, more often used on 8's. Without the power piston or other there can be a dead spot above 1/4 throttle. In any case it needs to be freed up.
In the base of the carb there should be a power valve, remove and make sure its clean and moves. A stuck power valve will dump fuel in the carb somewhat like yours is doing
The power valve is new, I'll double check that it's moving. So sounds like a seized power piston would not cause my problem? Thanks for all your input!
