Ozark littlefish
Thread starter- Joined
- Apr 24, 2006
- 9
Has anyone ben able to keep shad alive? I can net them well enough, but they die in no time.
jtexas said:Striper guides do it with fancy oxygenated bait tanks like these. <br /><br />I've just acquired a cast net & learned how to use it & been doing some research...what I've found is<br />* don't let the water temp in your tank get much higher than 72 - add ice if you need to<br />* you have to continuously filter the water<br />* if you're using city water, add some salt - one cup per 10 gallons - and something to neutralize the chlorination. Not sure if you add salt to lake water, probably not.<br />* oxygen - I just bought a couple of these air pumps on ebay, I'll let you know how it works weekend after next. <br />* In a square tank they all pile up together in a corner and use up all the oxygen, is why the fancy bait tanks are round, and keep a gentle current flowing.<br /><br />Those expensive tanks have pure oxygen injectors - too pricy for me. I'm going to add a filtration pump, and try it in an igloo cooler.<br /><br />good luck!
