GT1000000
- Joined
- Jul 13, 2011
- 4,916
I used 2 each, 3/4" S x Mips adapters, connected through the hull with a short piece of 3/4" PVC tubing...
First, I used PVC cement to glue one of the adapters to the length of PVC pipe, which I had carefully measured and cut to keep the adapters tight to the the hull, yet have good insertion length...
Then, I applied marine sealant to the opening and the outside of the PVC tube and slid it into the opening...
I wiped off the sealant on the PVC tube that projected inside the hull, making sure the inside of the tube was clean, applied the PVC cement to the other Male adapter and pushed it on tight to the inside of the hull.
After letting that set up for about a week, I screwed on the shut off valve and as of this time, I have only done some test fitting of the pump.
The location and angle of the pump should be in a good position to be able to pull up the water...although I won't know for certain until I actually get this tub in the water...
The shut off valve has the same 3/4" threads as the threaded extension on the pump housing...
And there shouldn't be any flow restriction since all of the internal dimensions of the fittings are basically 3/4"...
Hope that helps...
Hope that helps...
