daddiodave
- Joined
- Dec 18, 2018
- 12
I just bought and old boat that has a live well that is not connected to anything. Diagram attached. I just want to be be able to fill it and then drain it.
There are 3 thru hull fittings on the boat. They all have ball levers attached. One of them is being used for a deck wash down but the other two aren't hooked up to anything. Whats the best (easiest) way to fill and drain it.
I was thinking a live well pump from one ball valve to the top fitting of the live well to fill. Not sure on the drain since the other thru hull is below water as well
