navigator336
- Joined
- Jul 27, 2003
- 270
Re: Livewell/Baitwell design - Input needed!
Right on all accounts except it will be pressure that moves the water out the drain rather than suction. The pressure is from the "hydrostatic head height". The water height in the riser will of course be the same as that in the tank. As the tank height rises, out goes the water through the drain which prevents the tank height from really changing at all (the drain is much bigger than the inlet). The bleeder hole size doesn't matter much. An 1/8" is fine, but a hole that will accomodate whatever short tube(like you guessed, an inch or two vertical) you can find will make it easier to attach the tube. I can e-mail you some pictures of a 35 gallon tank if you want, but it won't be until Tuesday.
