Just purchased a 2007 Crappie Master. Need to know how the live wells operate. Front live well starboard and rear live well port side. There are 2 cable switches at the driver location for both. Recirculate and pump out. Also at the driver location is a live well "recirculate" auto or manual. Then on the front of the boat there's a "fill live well" switch. Then if you skip over one switch there's a "port/off/starboard" switch(not sure if this goes with them but what else could it go to). Today we could get the rear live well to fill alittle but then had to fill the rest of the way with the "recirculate manual" switch. I could turn on the "fill live well" switch at front and we could hear a motor running but nothing happened. Just need to know how these are supposed to work so I can start working on them if need be...Also, it took awhile for the water to drain out of the rear live well once we were back at home. Is there a way to pump it out with my set-up??? Also, there are 4 holes on each live well...Thanks!
