bluegill_fly
Thread starter- Joined
- Sep 25, 2012
- 5
Pardon me of this is a dumb question, but I'm a boat noob with his first boat, so...
Earlier in 2012, I bought a 1984 Livingston 12 for a project (install some decking to make a mini-bass boat, basically). It was garaged at my old house, but there's no garage space at the new place, so it's been out in the yard under a plastic tarp for the last month. It sometimes rains even in southern California, and we've had quite a lot lately. Upon looking under the tarp today, I found about 8 inches of water inside the boat. The tarp apparently has some watertightness issues <g>
So, with an assistant, I pushed my now really heavy boat out into the middle of the driveway, pulled the drain plugs, and raised the trailer jack. All drained out now, but on both sides just inboard of the drain plugs, there is a groove in the floor with a small round hole at the front. These holes open into the catamaran hulls of the boat, and because they are lower than the rest of the floor they still have water in them. My questions, then, aren't about the drain plugs per se, but about these grooves and holes:
1) Both of the holes at the heads of the grooves are open. Should they be, or are there plugs that should be in there? If there should be plugs, are they rubber, or what? Can I buy or make them?
2) Because they are open, are my catamaran hulls now full of water? Are those hulls hollow or filled with foam?
2a) If they are now filled with water or waterlogged foam, what is the best way to take care of it?
3) What is the purpose of the floor grooves and the holesin the cat hulls?
4) Anything else I should know about them?
Thanks,
Jonathan
Thanks,
Jonathan
