Livorsi Wire harness diagram
Leedanger
Does anyone kindly have the pin out diagram for a 2014 livorsi emc eec0016062?
I’m working on a boat that won’t crank and I feel reasonably confident this remote is the culprit but I can find a pin out anywhere so I can confirm my suspicions. Anything you got would be much appreciated
Fun Times
Did your online search of something close to “Livorsi marine Wire harness diagram livorsi emc eec0016062” get you close to finding a pin layout that may possibly work on your model?
Though it may not be listed mostly because of the manufacturer involved vs possibly some others out there that may keep their literature a bit more updated annually.
I haven’t followed Livorsi service process to know if they change their wirings around often or keep it easy and stay consistent.
With that mentioned and not talking with Livorsi directly, with careful examination, page 5 of the following 2017 revised manual may offer a guide for you to see if the wiring colors are of the same and in same order to help perform the desired tests you’re attempting to do…,
Other info may found inside the following too…
