76SeaRay
Thread starter- Joined
- Aug 24, 2017
- 1,071
While waiting for delayed shipment (seems to be common these days) of parts for other areas, I am trying to sort out whether to change to U shaped front motor mounts (heavy 5.7L vortec with closed cooling system). The originals were boxed in old style. After watching all the videos and reading all the threads, I didn't see much discussion about the point at which the U mount contacts the hull and whether point loading there could cause stress cracks in the hull without some underlying wide piece to distribute the load horizontally along the length of the mount before being absorbed by the hull. What I have seen (unless I missed something) is that the legs are typically 1 1/2 inches or so thick, about 8 to 10 inches apart front to back, 4 to 5 inches wide side to side, and set directly on the hull with PB and tabbing. I am using all marine grade 3/4 inch plywood in this area so thinking that maybe I should lay down (brick mortar bedding style) a piece of the plywood over the hull area slightly longer front to back under the legs of a U mount. I know the tabbing will help distribute the load but don't you risk the tabbing eventually cracking and increasing the point loading without extra structure under them? Am I overthinking this or being overly cautious?
