FreeBeeTony
- Joined
- May 15, 2002
- 3,997
No sure where the high pressure bypass is? What you really need is one of these.
Also if you are just blocking off the ports, go to H/D and get a few of those rubber chair leg covers (like the one on the exhaust riser in the motor picture). I have had them on the motor for two years now. No issues.
I thought about using that one but on a closed cooling system that is a return. I figure they use that side for a reason. Probably something like the cold water would not spread throughout the manifold and run straight up the riser or something.
