Log style to center risers
FreeBeeTony
Does this look like an acceptable modification to the hose routing?
betayv
Re: Log style to center risers
hi there yes look good, I have the same thing in my boat and work good.
f_inscreenname
No sure where the high pressure bypass is? What you really need is one of these.
Also if you are just blocking off the ports, go to H/D and get a few of those rubber chair leg covers (like the one on the exhaust riser in the motor picture). I have had them on the motor for two years now. No issues.
achris
More fish than mountain goat
Have a look at the manifold just below your chair leg rubbers... See what I see? A plug... Use one of those in the front of the elbow... looks much tidier and less chance of a failure.... Part# 22-41622. They are a whole $4ea from Merc....
Chris......
f_inscreenname
I thought about using that one but on a closed cooling system that is a return. I figure they use that side for a reason. Probably something like the cold water would not spread throughout the manifold and run straight up the riser or something.
achris
Errrr.. Don't remove the plugs from the manifold... buy a couple of new ones (the same as the ones in the manifold) and use them instead of the chair leg rubbers....
Chris.......
