Logic 2000 Live well
Grub54891
And why do you want to remove it? They are usually built in. How about some pics?
sfmaster
No Title
I already have the back panel from the Bilge area removed. The reason is due to unwanted cables that are strapped to the side and are no removable unless the straps are removed. Why they did that, I don't know. I think the live well comes off with the floor panel. Also, I would like to clean the inside thorough and make any adjustment to the wiring and hoses, if needed. The floor can definitely use new silicone. water filtrates inside. Below are some picture's.
Grub54891
Looks like someone has been in there before, I'm sure the fuel sender don't come from factory with silicone on the wires, and I've seen a lot of senders. The wiring should be kept high as possible to keep any connections dry. Looks like you are doing ok so far and it does look like the screws you pointed out need to be removed to access the area. A pic a little farther away would give us some perspective of the area also. While you are in there, check all the fuel hoses for weather checking, and see if that sender was leaking for some reason in the past. If it was, replace it. If the deck goes under the helm area to far, it may have to be removed also, been there in the past, hope yours just is slightly slid in there.Good luck!
sfmaster
Thanks. I will take a farther picture and post it. I did notice the helm area , I'm hoping it would just slip out. I will take pictures along the way, this way I can share them with future boaters who need help as well.
sfmaster
I removed it, wasn't bad at all. Now I'm going to clean and maintenance the area then put it back together. Thanks for the help..
