FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
It will have a lot more drag, Fuzzey, and it will be harder to maneuver and more likely to hit bottom or other obstructions. Whether it will plane depends on factors we don't know.
If you absolutely have no choice, think about a jack plate, even a fixed jack plate, to raise it to proper rigging height.
ok thanks im buying used so long and short shaft is not something I have to choose from. I like the idea of a homemade jack plate because they retail for a lot. Did you bend the metal yourself or find something the right shape? more details would be appreicated.
that plate was designed for the 250Lb motor, 3/16 aluminum, i had bent, material and labor for metal $50. if using a small motor 10 and under, you can use 4 pieces of aluminum angle, use 2 pieces each side to make the Z shape. some extra holes drilled in it can be adjustable.
