Long block replacement suggestions
Wackybily311
Luhrs 320 tournament. I have two marine power 454’s with PFI from 1997 that I am wanting to replace. Does anyone know of some reputable manufacturers for these long blocks? Wanting a warranty and I don’t want to be thinking about if the place I bought it from torqued the crank mains properly when I’m 50 miles offshore…
Mighigan Motorz, or you can order from Marine Power or have your motors redone at your local machine shop.
mr 88
If money isn't a problem, I would be dropping 502's in . Same footprint, same transmission and prop shaft . Props would be different, that's about it . The 32 Tournament is no speed demon with the 454s , the 502's would be a huge improvement in that department.
